Looking for a new prop.
waiddog
I have a 1975 chrysler 75hp outboard. The prop I have is a michigan wheel I believe its a pr82. I want the same prop just new. the one I have is alittle chingered. It is a 18 spline NO through hub exhaust.
Re: Looking for a new prop.
Ayuh,.... I'd think the best way to get there, would be to call Michigan Props to see if they still carry it...
Frank Acampora
Those props are no longer available although you can find a couple on ebay. Look for the diameter and pitch stamped between the blades--it is there on the stock props.
I do have a couple of them so see my private message to you.
waiddog
Thanks Frank. got them today.
