looking for help identifing a 70's or 80's evinrude
wolfriver
looking at a motor to purchase and the common serial tag in the side of the shaft is missing?? Are there serials anywhere else on the motor. how can I find out more about this motor..Any help would be greatly appriciated
papasage
Re: looking for help identifing a 70's or 80's evinrude
post a pick and some one could git close . the plug on the top of some motors some times have the # on it .
wolfriver
upon clser examination it looks like the serial tag was removed this thing is probably hot.. I'm not having anything to do with it
1980, well the decal on the cowl is
MJ76
There is a picture on the ebay link that shows a top view of the motor with the cover off. If you look to the bottom left of the flywheel in that picure, you will see a small freeze plug. The model and serial numbers are stamped there. According to a buyer's question:
Q: What numbers or letters are on the freeze plug located on top of the engine just to the rear of flywheel? Thanks.
Sep-12-06
A: There are 2 lines of numbers first line reads E15RLC5D Second line reads E0001515 hope this helps.
The model number would be E15RLCSD, which would make it a 1980. I wouldn't worry about the tag missing, they are only held on by two puny little rivets, and it wouldn't be unheard of for it to disappear after 26 years. Also, the same motor (9.9/15) was made by Johnson/Evinrude from I think 1977 to 1991 - there are zillions of them out there, parts are easy to
find. Hope this helps
Scaaty
Gee, the jerk took FIFTY photos? My God...
