Losing rpm's+mph
Dave Abrahamson
Hey all 1st time poster here in i/o.
My BIL (up in NH, so too far away for me to be of much help except for you guys here on the forums),has a Trophy 2052 cuddy w/ a 4.3 merc that has lost about 6-800 rpm's wot. 45mph down to around 30ish mph.
His mech said to drop from a 19p to a 17p prop, but it has run fine for the last couple years with the 19p. I said to look for another mechanic.
I have never wrenched on an I/O so what are some of the obvious things I sould tell him to look for? Plug wire? Gas filter?Throttle cables? Why would his mechanic want him to change props when the current prop has been operating fine for a couple of seasons?
Sorry to be so long winded, but I told hm if I were able to find help anywhere.....it would be on Iboats.
Thanks guys...he'll be reading this I hope.
Dave
JustJason
Re: Losing rpm's+mph
Start with the basics, do a compression check and a spark check to make sure he hasn't lost a cylinder. Double check the advance timing (although if no ones touched it, it shouldn't change). If that all checks out then on to the fuel system. I'd put a vac gauge along with some clear line inline to check for restrictions and air.
Where abouts in NH is he? he could always call me :)
Dave Abrahamson
Hillsborough.....a good haul from you probably.
Betcha there's a good fishin' trip in it for ya if ya fix it though. ;)
JustJason
Hillsborough is to far for me....
Now if it was in hillsborough county..... then he'd be my neighbor
Dave Abrahamson
Thanks anyway CaptJason, nice to know there are people out there willing to help out a stranger in need. Ziggy, good post, thanks for the link.
Hope he finds the problem....it fishin' season up there...if I remember correctly, it only lasts a couple weeks in NH ;)
Coors
That Don's link will usually get you going.
