Lost my Shift Linkage Bolt so I made a new one
Not sure if this is good or bad. But anyways, couldnt find my old bolt that helt my shift rod into the shift clevis.
So I used one of my old water pump bolts and turned down the end of it (approx to the thread minor dia).
Seems to work like a charm. I dont even remember what the old bolt looks like. But I think this should work.
Grub54891
Re: Lost my Shift Linkage Bolt so I made a new one
I belive the correct one has a groove under the head of the bolt for an o-ring. How ya sealing it?
Grub
emckelvy
I'm thinkin' that bolt is not going in the lower unit, he's got a 70hp which uses a cut-down bolt at the top to capture the shift rod into the clevis (aka Shift Rod Lever).
No O-ring required there, although I'd be inclined to use a lock washer (but I don't find one in the parts diagram).
Just a thought..........ed
Grub54891
Ah, I was thinking of the one in the gearcase,I lost mine too. Have to find a new one soon!
Sorry the late reply. Im not getting my email notifications.
Emckelvy is correct. It is the shift rod linkage bolt.
