lots of questions on my 150 merc
jbonefc3s87
i have a 150 hp black max. i have no idea what year it is and i need to find a lower unit for it. there is currently no lower unit on it, didn't come with it. i found a serial number 6424412. not sure if it helps. Also wanted to know if i could run the motor without the lower unit on it. I wouldn't think it would hurt it, seeing how the water pickup would be off. ??? thanks for the help!
Faztbullet
Re: lots of questions on my 150 merc
1984
Any V-6 lower unit from 1981-2000 with 2.1 gear ratio
Yes, but install a garden hose to water supply tube so the block does not overheat....
jbonefc3s87
thank you so much for the info! I have been stressed out trying to find the information on this motor. are these black max motors a good motor? if something should happen to it, is it worth rebuilding?
jbonefc3s87
so now im confused. how do i look this up myself? how do i find the shaft length?
Fun Times
Sorry for the confusion.:redface:
You would be able to find most of your information in the link below, But the information I provided should be 100% accurate, Because that is what Mercury marine has listed under your engine serial number.;)
http://www.maxrules.com/Merc_model_files/115-150.html
Going by the (ELPT) I posted your shaft length is considered a LONG SHAFT (20")
(E) stands for, ELECTRIC START
(L) stands for, LONG SHAFT (20")
(PT) stands for, POWER TRIM
jbonefc3s87
what is the best pitch prop for this 1983 black max. on a 18' skeeter starfire? also how many blades? 3 or 4? what are the differences?
j_martin
This is an engine forum, not a library.:D
Props are a whole subject to themselves. The answer to each of your questions is "depends on.......". Maybe that's why there's a prop forum on iBoats.
hope it helps
John
