Low Oil pressure 454 Mag
stinger222
I've got a 454 with about 150 hrs on it. Running 15-40 wt Rotella only about40 psi 3000rpm cold oil, only about 20 psi hot, practically zero psi when hot idle. No noises from motor, runs ok, but have lost about 8 mph off the top end from last season (48 down to 40). Motor runs about 150 deg, never oveheats. I switched to KN high $$$ oil filter, no difference, and yes I tried a mech oil gauge to verify readings, and it was identical to elec gauge. Is my motor dying a slow death? I've never had a running engine with such low oil press readings. This is an 89 Chaparral 2550 SX
mkast
Re: Low Oil pressure 454 Mag
Time for a new oil pump.
Bearing clearances regulates oil pressure.
One or the other or both.
45Auto
As Shrub says, running multi-weight automotive oils in a boat is not generally a good idea:
Multi-grade ratings of petroleum oils are made by adding polymeric plastic thickeners to an oil with a very light viscosity. An example of this is 10W-40 oil, which is created by thickening a 10W oil to the equivalent of an SAE 40W oil at 212 degrees F. The reason a 10W oil is used is to maintain low viscosity at low temperatures; this helps with engine startup and cold weather performance. The thickeners increase viscosity at higher temperatures. Unfortunately, when the large molecules of the polymer thickeners encounter a high-stress area, like a bearing, these big molecules tend to align themselves to create a path of least resistance. This greatly reduces the film strength of the oil; the result can be an apparent viscosity that is much lower than the viscosity listed on the container. In fact, a standard 10W-40 oil, when subjected to high stress, may perform to SAE 20 specifications, simply because the added thickeners cannot cope with the additional stress.
Latest oil recomendations from Merc:
Pay close attention to the NOTE just above the white chart. However, if you don't like the manufacturer's recommendations, run whatever you feel like. You'll find plenty of people to support whatever you choose if that's what it takes to make you feel good! :)
jaxnjil
not to discount what the others have said but i doubt your oil viscosity is your problem.
this is what the mercuriser manual says for you problem
Verify with an automotive test gauge. Refer to
Section 4D for instrument testing.
Thin or diluted oil
Oil broken down; contains water or gas; wrong
viscosity; engine running too hot or too cold;
excessive idling in cold water (condensation)
Oil pump
Relief valve stuck open; pickup tube restricted;
worn parts in oil pump; air leak on suction side of
oil pump or pickup oil tube
Oil leak can be internal or external Oil passage plugs leaking, cracked or porous
cylinder block
Excessive bearing clearance Cam bearings, main bearings, rod bearings
wca_tim
I'm sorry, but I'm missing something perhaps... and not trying to start an oil arguement thread... It is highly unlikely that Rotella T 15-40 does not easily satisfy all of the requirements for NMMA and FC-W ratings. It is a heavy duty diesel and offroad oul with one of the most complete detergent and anti-scuff additive packages of any of the widely available oils on the market. It is a quality oil and what my engine builder recommends especially in engines with flat tappet camshafts. It is probably a little thin for standard marine engine aplications and change intervals, but it is not thin enough to show the problem that you're having.
You've got a pressure "leak" or other problem as mentioned above... somewhere...
stinger222
thanks for the replies...I have always used this oil on my boats and have never had a problem. I took off the port side valve cover to check things out, fired up the engine, plenty of oil squirting around. Is it normal to have a small river of oil flowing back down the outside edge of the head towards the back while the motor is running. I've never looked at a motor running with a valve cover off.
danond
Yes, it's typical to have oil flowing back. That needs to happen or it fills up in the valve covers.
stinger222
I cut open oil filter from recent change. Some metal shavings in the bottom. I'm guessing there shouldn't be any metal in there at all.
Ayuh,... That's correct,... I'd Guess you're probably loosing a main bearing or 2....
stinger222
10 psi today at 3000 rpm with the engine warmed up. I am going to take it easy and try to make it to July 4th weekend. In the meantime I'll keep the Sea tow # handy. After the 4th I'm pulling the motor to rebuild and stroke to 496, upgrade to roller motor. Any oil recommendations to buy me insurance for 2 more weekends? Do they make straight 50 wt oil? Someone told me to try Lucas oil additive.
jaxnjil
sudden loss of oil psi + metal in the filter
dont take a chance. motor needs to come out and find out whats wrong with it. if you blow it up at best you lose your core or good chance you'll ruin block for rebuild. worst case you drop a rod out the bottom of the pan and bust a hole in the bottom of your boat. not likely but possiable.
stinger222
Ran this by my mechanic. He said that if the oil pressure was really that close to zero at idle, there would be quite a bit of valvetrain noise, given the top end would feel the effects first of low oil pressure first. The fact that there was a pronounced "river" of oil flowing along the edge of the cyl head at idle along with oil squirting everywhere with the valve cover off leads him to believe there might just be a restriction somewhere near the oil port where I am getting the pressure readings (with elec or manual gauge). I changed the oil to straight 50w valvoline along with 2 qts Lucas oil stabilizer. I'm going to run it the rest of the summer and be easy on it and then rebuild over winter. If I smoke it before then I guess I'll be buying a 502 crate motor!!!
stinger222
well its Aug 15th, still only 10-20 psi hot oil press, have been using the boat every weekend. Now the goal is make it to Labor Day weekend? No noise from motor at all.
The oil pressure dropoff back in May was also accompanied by a dropoff in top end performance, unless it was a coincidence. Top end went from 45 to about 35...something is going on, but the thing keeps running!
dr_bowtie
i'd pull it....
you could have a spun bearing more likely a main bearing...
you wont hear any top end noise with low oil pressure because the way the oil system works it does the top end 1st the and the bearings/crank last...
when you run out of oil the first thing to get shorted is the rods/crank....thats the way it works...the mechanic you talked to should know this....
this is how it keeps the lifters pumped up...it gets those first then the mains...it is possible that the oil bypass in the filter adapter has busted as well...this is common on motors that run full bore with thick oil...
I would pull the filter and pull the adapter and look at the bypass...I just changed on in a engine where the spring broke from heavy oil...
if the bypass sticks open the oil gets in a loop and never goes into the engine...it goes from the pan to the pump and right backj into the pan...
if the bypass is fine I would pull the engine and start checking it out...
a 454 can live on 4psi as long as it isnt beat to death...
there are several things that can lead to low oil pressure...loss of bearing clearance and thrust surface...if it eats the thrust bearing presure and go to...
spun cam bearing or any one of the mains....if a main spins most of the time you wont hear it....
best bet is to check the bypass 1st that is the cheapest route...
Polar_Bus
I've experienced this before, and really the only suspect from what you are describing is bad crank and or rod bearings....
stinger222
UPDATE: Low Oil pressure 454 Mag
Well I have been driving the boat all summer every weekend, boat still runs, no noise, oil press still between 15-20 psi max at around 3300 rpm, 5 psi at idle. My mechanic pointed out that the shiny metal particles in the filter are probably from the oil filter can being sawed in half...good point! Back in June I changed the oil to straight 50 wt valvoline, and substituted 2 qts with Lucas oil. I never ran above 3500 rpm all summer. Maybe that is why it lived.
Still pulling the motor this fall and will tear it down a rebuild it as a 500hp 496.
Bifflefan
You need to stop running Rotella oil. That is for Big truck desiel engines.
You may say well if its good enought for a big truck then its plenty tough for me,,,Maybe. But still its not...
The oil pressure is low because you have worn out all the bearings in the motor. Again probably because of using that oil. As for it not making any noise. The warning signs are there right now.
HEED THEM.......
stinger222
HEED THEM.......
I only had the Rotella in there for a few hrs run time. The previous owner used AMSoil 20-50w synthetic.
