Low Voltage
COL BRADDOCK
Hi all,
My Voltage gauge is reading 10-11v. Cannot run my accessories. Reads 10-11v with key on. I start the engine and it still reads 10-11v. All other gauges over-read slightly (fuel, oil px, temp). Ran it for a couple hours and on the lake and it seems to work ok.
Cleaned wire to the starter. Starter also seems a bit weak
This happened a couple weeks ago and I cleaned up the wires on the alternator and the problem disappeared. Did the same thing with no joy.
any ideas???
98 4.3L GL Volvo
Boat gauges can be off, Use a handheld meter and measure battery volts when running. Should be 14.5V about 1000 rpm
