Low water PSI reading while running
CaptainYARRR
Hey all,
Been getting a tricky fault that gives me the two beeps but clears all codes when I get to dock. I put my Rinda computer logger on it and ran it. The boat is happy under 3500 RPM. If I go over, it triggers the two beeps, the log says SENSOR FAULT.
Watching my log, my water pressure sensor is reading anywhere from .04 at idle to .5-.11 typically with blips up to 5 PSI. If I go WOT, it will go to 10 PSI.
I'm watching the coolant temperature parameter and it is pegged at 141. The mechanical gauge doesn't move off 160. So I feel like this reading is in error.
The pressure sensor is a year old. No salt water use and probably only 5 hours or so use. Engine is an 05 Merc 6.2 MX MPI serial starts with 0w0.
Going out to the boat tomorrow. What trouble shooting steps should I do? I imagine pull the sensor and inspect for garbage in it. What else?
I would mechanically read the pressure myself.
CaptainYARRR
Makes sense...where would I pick up a gauge? Guessing just need a Home Depot water pressure gauge, hose and a barbed fitting to plug in the blue drains?
If that checks out, sensor issue?
CaptainYARRR
I really apparently hadn't drank my coffee yet, I think I saw boat and repair then posted away! Yes, if I could be moved that'd be great or I can repost.
Fun Times
I was able to move the post over for you.
If the Rinda tech scan tool read 140 degrees then there's a really good chance that that's all it's getting up to temp wise and should be more in the 160 - 163 range on average while in a lot of cases (not all) the dash gauge tends to read more in the 170-75 range.
May want to open up and inspect and most likely change out the thermostats as it's pretty common that it needs replaced once it starts showing low temps.
Bt Doctur
Get a new sender , hook your ohm meter to it and read the resistance at various power levels. Then go to Radio Shack , buy resistors of that value and hard wire them into the harness.
Locate your temp gauge and always keep one eye on it and you`ll be just fine
