Lower Unit gear tooth broken
16Pilot
I recently rplaced the retainer plate behind my carrier housing and noticed half of a tooth was broken on my drive gear coming down from the upper housing. My quetion is can I use it this weekend because I have had this trip planned for six months? Thanks guys, I know this is a stupid question but I do not have enough time to have it replaced. -Chris
Re: Lower Unit gear tooth broken
Just make sure you have SeaTow, or there are plenty of people around so they can tow you back in. They shouldn't mind the inconvienience.
tommays
i would be suprised if it did not have a bigger failure resuling in a much larger repiar cost<br /><br /><br />something had to realy stress the drive gears <br /><br />your allready realy luckey it did not fail on the water<br /><br /><br />tommays
16Pilot
I am definitley not fixing it, I plan to sell the damn thing because it has been one thing after another. I put a new motor in it and all new electrical. I am finished with the stupid thing. I am going outboard next time.
16Pilot
I was told it would be a $1000.00 or more to fix it.
Limited-Time
If yer sure you’re not placing yourself any one else in any danger if/when problems arise...(safety first ya know). And if yer not worried about possibly breaking down off shore, or inflicting additional damage, and increasing repair cost…go for it. But I would not.
Originally posted by 16Pilot:<br /> I am definitley not fixing it, I plan to sell the damn thing because it has been one thing after another. I put a new motor in it and all new electrical. I am finished with the stupid thing.
And All This Time,......... I Thought That Was the Definition Of Boat Owner$hip................ :D <br /> Break<br /> Out<br /> Another<br /> Thousand<br /><br />I'm Truely Sorry to hear of Your Problem,..... But I Agree with Everybody else.........<br />Run It,+ It'll be a Short Trip........<br />And,... There Won't be much Left to Fix............
Trent
I see you bought a OMC.... New motor too? Sorry bud. As Bondo says BOAT!
KaGee
The lower unit is somewhat common... look to ebay to replace it. <br /><br />Something had to cause that gear to break. Something bound up or the unit hit something at one point. Gears don't just break off a tooth for no reason... well maybe if there was a flaw in the casting.
Scaaty
Simple answer. That 1/2 tooth is taking the load of a full tooth (also stressing the others in contact). When it breaks off, the following tooth will from zero contact, to the equivilent of a hammer blow when the tooth comes in contact again. Basically, this is how s$$t breaks. Could have been like that for a while, or the last time ya shut it off. Plus where is the missing part of the tooth? Not the answer ya want, I know, but the truth is I would park it until fixed.
tommays
at this point you spent all this time fixing all the problems ANY USED bost is going to have<br /><br />and you know what you have now<br /><br />if you buy another boat you going to be right were you started with this one USED OUTBOARDS break to and the parts really cost :eek: <br /><br /><br />tommays
16Pilot
It ran fine all weekend. I took it easy and trolled most of the day. Anyway I guess I was lucky. I am still going to sell it though. Thanks for all of the help guys and happy boating !
Wellcraft 89
Thanks for telling the next guy about the problem,he will apreciate it.<br /><br />Rich
16Pilot
I actually plan to give the next guy the gear and let him take care of fixing it. I got a great deal on it so I picked it up. installing it is the expensive part.
