Lower Unit Leaking
Working on a '58 Evinrude 35 HP Big Twin. I've replace all the seals on the lower unit and I have oil leaking from the seam where the two halves meet. I couldn't find the 3M 847 others here have suggested, but I used Permatex "aviation" sealer (brown) as some others suggested. I filled it with oil and it initially didn't leak (24 hours), I then ran it in a drum, and after sitting another 24 hours I have a quarter sized puddle on the floor. Any suggestions?
Re: Lower Unit Leaking
There was a spagetti seal in that seam on my early sixties big twin. Do you have one of those? I used to use Permatex #2 non-hardening sealer on the spagetti seal. The aviation gasket is thinner, and may not seal as well.
SparkieBoat
also you will get some oil spots from the exhaust from the unburnt 2 cycle oil after running your motor, that is normal.
I did replace the spaghetti seal. Coated it in the Permatex Aviation Sealer. The new seal didn't seem to fill the grove entirely, but I figured it would when the two halves were pressed together. I guess I will be pulling it back apart and using a different sealer. Luckily the seal kit came with enough spaghetti seal to do the job twice (groan). Thanks for the input!
jtexas
you can get 3m #847 at ishopmarine dot com
