Lower unit seal/gasket kit, water pump kit 92 90HP Force
dcar00
Hello,
Can anyone give me the correct part numbers,Mercury or Sierra for 1992 90HP FOrce
water pump kit
anything else I should replace, besides gear lube/drain/fill plug washers when taking off the lower unit?
thanks
Re: Lower unit seal/gasket kit, water pump kit 92 90HP Force
Mercury part numbers
FK1203-1 SEAL kit
FK1204-1 WATER PUMP KIT
