lower unit???
skynyrdcat
Just bought an 86 stingray with a 140 mercruiser inboard (0A685269) but the serial number on the drive has faded off.
How can I identify it so I can get a new impeller for it?
Thanks in advance
jerryjerry05
Re: Identifying a lower unit/ stern drive
Just tell then you need an impeller for an alpha unit.These impellers are all the same.They didn't change for a lot of years.Jerry
Ayuh,..... 1986 would be the Alpha 1........
All of the Pre-Alphas use the Same Impeller....
The Gen.IIs are a different 1,+ they came out in 91 I believe......
skynyrdcat
I planned to order it from IBOATS and I don't see ALPHA1 or ALPHA 2 all I see is part numbers.
BAYLINER185
Re: lower unit???
You can use an implellar for an Alpha one Gen I or MR and R stern drives.
Those impellars are all the same. The Gen II uses a biger more aggressive looking implellar.
