Made a heck of a good deal on ebay(update 10/19/2010)
cajuncook1
Re: Made a heck of a good deal on ebay(update 10/19/2010)
Well, the motor, fuel tank, and owner manual arrived today!!!!
compression out the box = 70psi/70psi
spark= 1/4 gap on the spark tester (good)
Fuel= started on second pull and I adjusted the slow idle needle some. Runs pretty good. It smoked alot at first but fuel/oil probably accumulated near the head during shipping. After a little bit it resolved and adjusting the slow idle needle helped.
I did note that a very little water was being pumped, so I shut it down. Will drop the lower unit and replace the impeller and check the lower unit oil.
Here are a few pictures of motor fresh out the box and a short video!
Click on the movie to play!
Coooooooooooooooooooooooolllllllllllllllllllllllllllllll
Thanks for checking the pics and movie out. (Total for motor and shipping was about $100)
lakelover
Looks like you came out on top. I had a 9.5 Johnson (1969) that I got rid of a few yeas ago that had 60/60 compression. It still ran OK, but was tired and I wanted something that I didn't have to mess with all the time. It had got to the point where the gasket that separates the head from the lower exhaust had deteriorated and a lot of the smoke would come up under the hood and choke it out.
Mine only sprayed a mist of water until it heated up and the thermostat opened up. That's normal for those. It looks pretty clean. I used to love the way the handle folded down out of the way for carrying & storage.
How does yours run with the hood on?
cajuncook1
It runs fine with the hood on, so no exhaust leak as of yet:D I have 2 other 9.5hp motors and they put out a lot more water. I don't know when the water pump has been replaced on this motor, so I am definitely going to replace the impeller. I plan on doing a seafoam decarbing just to get it cleaned out.
Cheers
mercury713
Nice find... paint on heads look nice.
Jeep Man
A forum wouldn't be a forum without a few naysayers. Congrats on your purchase. I'll give you $75 and pay the shipping. Easy profit!:D:D
kenmyfam
Looks like a great deal. Well done. :)
Gary H NC
That was a heck of a find! Congrats!
Glad it worked out.
Biged007
hope you gave the guy a A+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ on his feedback :D
D
DJ
Guest
Great find!!!
Those engines had their oddities but were great fishing motors.
Give her a good dose of Sea Foam in the fuel. That will clear up any carbon issues.
