Manifold and Riser Sealants?
nigels
Hope to install new ali manifolds and risers this week (if it stops raining) and wondered what sealant is best to use on the riser gaskets and what sealant if any on the exhaust gaskets?
I have read the manual and several threads however any other useful tips for this procedure will be greatly appreciated.
1999 4.3 MerCruiser
Jmunk
Re: Manifold and Riser Sealants?
The gaskets are designed to go on dry, make sure your surfaces are clean.
nigels
Thanks guys, for you input, I didn't know about the new torque numbers, either!
