Marine plywood near OKC?
Re: Maine plywood near OKC?
Usually you can order it from a lumber store but be prepared for major sticker shock!!
Welcome to iboats! :D
What are you building? 90% + here use exterior plywood that has been sealed with epoxy or polyester resin and glass.
wallybme
Re: Marine plywood near OKC?
You can get them from LUMBER 84 or can be ordered through Lowes.
barrrj
I wasn't able to find anything in okc. I used AC ext from lowes and coated it with epoxy resin to seal it.
Ayuh,... CDX works for stringers....
archbuilder
Forest lumber on May Ave. has all you want, both 1/2" and 3/4". Very nice stuff, that is what I have used on my boat.
Hunter1st
If you can't find it in OKC, Fort Worth Plywood has it. I've also been using epoxy from a guy in FTW that mixes it for Lockheed.
