Marine vs. Automotive gear lube
LEROYDOZOIS
I WENT OUT AND BOUGHT SOME PENNZOIL MARINE 80W-90 LUBE WITH THE API GL-5 PERFORMANCE LABLE
SITTING ON MY SHELF I HAVE SOME VALVOLINE 85W-140 OIL THAT I USE IN MY SPORTSTER, AND I REALLY LIKE THIS STUFF:D
THE VALVOLINE OIL IS ALSO RATED API GL-5 ALONG WITH ANOTHER 6 OTHER GRADES...
SO COULD I USE THE VALVOLINE OIL IF I RUN OUT OF THE PENNZOIL OIL??
JUST CURIOUS :p
marcortez
Re: Marine vs. Automotive gear lube
Yes, if your particular system calls for 85W-140 weight oil.
LEROYDOZOIS
soo, im guessing its mainly the api gl-5 rating that is important??
The GL5 rating is for pressure and anti scuffing.......
I would not put in any weight that was not called for and marine gear oil has more corrosion protection
LEROYDOZOIS
COOL ! THATS WHAT I WAS LOOKING FOR,
MY NEIGHBORE USES PLAIN OL 80W-90 IN HIS MERCURY, BUT ALSO HAS MANY PROBLEMS "MOTOR NOT OUTDRIVE" BUT ALOT OF THOSE PROBLEMS MADE ME QUESTION HIS INFO HE TOLD ME
THANKS FOR THE HELP GUYS
LeRoy
5150abf
lower unit oil has additives to deal with water intrusion that regular oil doesn't so it isn't the weight that is important.
If you get a seal leak and are using regular oil you will find out shortly why it isn't a good idea adn a new lower is quite alot more than a quart of oil.
