mariner 28e 664 l570954
mikew5432
bought this motor but seems to be missing some wiring or harness as the connections off the coils aren't connected and a white wire towards front next to stater wires?really appreciate a wiring diagram
Mohawkmtrs
Sure the serial # is posted correctly?
There should be no "I" in the last series of numbers. If the last series of numbers are correct, your 28HP motor is a 1979 model year.
QBhoy
HI
try searching for the Yamaha 28hp diagram. Much more commonly known and exactly the same engine. Mariner were Yamaha in those days. Good luck.
