Mariner lower unit crack near prop/exhaust hub
jdub2
Hello folks, I recently hit something and messed up my prop. The hit took a small piece about the size of a half of a quarter out of one of the blades, which certainly threw the prop off balance. Later on I found a 1-1/2" or so crack in the lower unit. I don't think it was there immediately after I damaged the prop, but it may have been. Or could it have been caused by running the engine with an off-balance prop causing excess vibration? What do you folks think, how serious do you think this crack is and should I be overly concerned about getting it repaired immediately? Of course, I'm getting a new prop before running it any more.
Thank you for any input you may have.
Below is a pic showing the area of the crack in red. This lower unit is not my lower unit, but it's similar and shows where the crack is.
jdub2
Re: Mariner lower unit crack near prop/exhaust hub
Anyone have any experience with repairing this sort of thing? Will this crack still tend to get worse with a new balanced prop?
westexasrepublic
drain your lower unit, if it comes out milky you probably already contaminated your LU oil. Im thinking the LU gears are whats damaged from the impact. If not just throw another prop on JB weld the crack and feel for vibration on your next outing...
The area of the crack appears to be behind the seal on the gearcase. If so, the gear oil should be unaffected, but check it out. if it is OK, seal it with some epoxy putty, and forget it. If not, consult a good welder....
Faztbullet
Be very careful as this is where threaded area is that cover nut screws into. If the crack expands the nut could jump the threads in a high reverse thrust event..yanking carrier,cover nut,prop shaft and prop into the deep six, seen it happen several times.
j_martin
At this point a good prop shop can weld that up, chase the threads, and with a lil paint, you'd never know it.
Let it go, and see the above said destruction scenario play out.
jdub2
Thanks guys for your input. I was looking at a shop manual and I think I see what you're talking about regarding the threads. I guess the right thing to do is to bring it in and get it fixed properly. I just have to chalk it up to experience. :(
