MC-1 165's. Drive install gasket question
ttownthomas
The manual, written in 1980 or whatever, says to use adhesive to hold in the o-ring and to install the paper gasket dry. Is that still conventional wisdom? The drives and transom assemblies have been rebuilt and freshly painted so they are clean and flat.
1974 Bertram 25, Twin 165's (replaced with 292 long blocks)
Bt Doctur
and with a bit of work those 292`s can be bumped up to around 300 horses each you would have to change the drive ratio to 1.47`s
