MC-1 lower unit will not lock into forward gear while separated after water pump replacement
utskicat
I have an old Mercruiser 888 (MC-1) drive. I just completed replacing the entire water pump and base and was getting ready to mate the upper and lower back together. I cannot get the lower to lock into forward. (Trying to do this by turning shift shaft clockwise while turning prop counter clockwise.) I can however get the lower to lock into reverse by turning the shift shaft ccw and the prop cw.
I have googled for several hours and tried various ideas with no avail. Here is what I have tried:
0. First I removed new water pump so I could observe drive shaft turning and not have pressure on impeller if turning backwards.
1. Put tape on shift shaft splines and used pliers to gently add some more pressure to turn it cw. No change.
2. Turned entire lower so that prop shaft is pointing down. Automatically locks in reverse (and takes a lot of pressure to turn shift shaft since its weighted)
3. Turned entire lower so that prop shaft is pointing up. Shift shaft is now automatically holding far cw and when I rotate prop shaft ccw, you can feel and hear it trying to engage gear but it does not fully engage and hold.
Any ideas what's going on? Everything worked before I took the drive apart. I'm praying I don't have a clutch dog or gear problem...
utskicat
try removing the lower drain plug.had one where the magnet was a bit too long
SOLVED!
You are the man!!! As soon as I read this, it made sense, I had removed the old drain screw (sans magnet) and put in a new one with magnet right before changing water pump. Its the only thing that has changed. I went out and pulled the new screw and sure enough, the magnet was already bent at a 45 degree angle. With screw removed, lower unit locked into forward with no problem.
I'm surprised that more people have not posted with this problem. Why does Quicksilver sell a part that doesn't work?!
Bt Doctur
Now, if there was a way to actually charge for correct answers............................................. LOL
