MCM 470, Stringer Drive, Engine Oil, Vaseline and cardboard!
Status
Not open for further replies.
kilowatts
Hi Guys:
I need some opinions please.
Last month my sister was remarried and I finally met my new brother-in-law. It turns out that early in his career he worked on the design team for the OMC stringer drive. Later on he moved over to Mercruiser and was the head of the design team for the MCM 470 and all the variants. He told me that the 470 was designed from the get go to bolt up directly to an OMC stringer!
When he retired he fixed up an 18 foot Bayliner cuddy with an MCM 470 attached to a Stringer drive just as he described. Not only that, but he designed the thing to run on McDonalds deep fryer oil and Vaseline 50-50 mixture. He said when he changed the engine oil at the end of the season it polished up the oxidized gelcoat on his boat just like new. He also said that the parts are readily and cheaply available and he gets 250 HP, 50 mpg and can run his Bayliner at 65 MPH all day long at 1200 rpm! Further, he fixed up a set of home-made hydrofoils on the stringer drive and planed at 3.4 mph.
When he rebuilt the deck he replaced the stringers with 3 layers of corrugated cardboard on end, covered with 2 coats of waterproof Elmer?s glue and the floor is 3/8ths D-grade OSB with 3 coats of interior semi-gloss kitchen paint and he said it holds up just fine.
I think I hit all the high spots, but what do you guys think?
kilowatts.
Re: MCM 470, Stringer Drive, Engine Oil, Vaseline and cardboard!
I think this is a stupid post. Were you trying to be funny?
Well...you asked!
havasuboatman
Ensign
You really have nothing better to do, do you?
JustJason
This is the sorta junk you normally see in late november... when it gets slow around here.
DBreskin
BruceB58, Havasuboatman and justjason, do you know what today's date is?
Ayuh,... Sounds like the descrpition of the driveline Don put together a month or 2 ago....
Now, where's the pictures,..??
Happy April Fellas......;) :D
nola mike
you guys have no sense of humour. my 470 actually does get 50mpg, but will only cruise in the low 60mph range. not a bayliner hull though.
Philster
Read this!!!!
OMC is BACK IN BUSINESS, with blue prints of everything and parts ready to go in just 60 days! JK Holdings is going to be shipping parts soon. Everything they ever made, and some new designs, too:
www.OMC/JK.com/newfor2010
attachment.php
crazyinkc
My eyes are bleeding!!!!!! Kill it with fire!!!!!!! BTW, I have owned both a 470 and stringers but never long enough to sink tons of money into.
kilowatts
Hi Guys:
I guess you never noticed the date today, eh?
Happy April!
kilowatts
Status
