Merc 1150 help
Ben.Skelton
Hello all. It has been some time since my last post, but find myself again in need of greater knowledge. I recently acquired a Merc 1150 thunderbolt with power trim and ptt pump. The motor looks to be in good shape but needs some TLC including a new lower unit. The old one is freeze damaged and the case is split. Easy enough though.. should be able to get the case of my 90 to fit. The 1150 is pictured below. Serial #36503427 What year is it? my Seloc doesn't say.
In regards to the power trim system and pump. How do I service it? how do I fill and drain it? What fluid should I use in it?
I tried to attach photos but can't upload them even with a resize... any tips?
sourbsted
Re: Merc 1150 help
If you have a smart phone, use the photobucket app and upload the pics off your phone. It's very easy. Copy the link and paste it..
carholme
Ben.Skelton
Re: Merc 1150 help
S/n 36503427 comes up as:
115 1150 6-cyl 3525441 3761034 1973 USA
Service Manual P/N: 90-68647
In the interim, here is a link to the condensed version of the Clymer manual which will get you started with the T/T system. Download it soonest to your computer as the link is short lived.
Small Engine Repair Reference Center Home: MERCURY - MERCURY IN-LINE SIX-CYLINDER MODELS (1969-1988).
T/T on page 317.
Gerry
The manual you attached does not appear to cover the style of pump and cylinders on my motor. The pump is remote... not mounted b/t the cylinders.
Re: Merc 1150 help
Lower units from inline 4 or 6 motors from early 70s to late 80s will fit your motor. IL4 gearcases may have different gear ratios.
Normally those PTT units take 5W-30 motor oil. However, Dextron II/III ATF is fine as well. See if you can determine what is already in there, and top it off.
carholme
Re: Merc 1150 help
Just noticed the s/n size. Can you check it to make sure that is the correct number? Yours has 8 numbers but the standard is 7.
Gerry
Ben.Skelton
Re: Merc 1150 help
Sorry, The number is 3650347. It is on the Tilt/ clamp bracket on the front of the motor.
Ben.Skelton
Re: Merc 1150 help
Also would you review the Pictures in the OP and point out the fill and drain on this contraption... Thanks
Ben.Skelton
Re: Merc 1150 help
Also would you review the Pictures in the OP and point out the fill and drain on this contraption... and what knob is it talking about?
Thanks
mr 88
Re: Merc 1150 help
The knob is missing,supposed to be on the 1/4" exposed threaded stud that is below the signage.There are two screws on top of the reservoir the lower one is for filling and the upper is for venting.You can use a funnel to fill it up or take the pump assembly off your quart of lower unit oil and screw one end into the fill hole and the other on a quart of regular oil.Loosen up the vent screw or remove it while you fill her up to the top of the fill hole.Before you hook up the lines to the pistons run the unit a couple times to flush out the system,then refill.
Ben.Skelton
Re: Merc 1150 help
Would anyone have a picture of the correct knob? or suggestions on how to replace it?
mr 88
Re: Merc 1150 help
You can probably "lock" two nuts on the stud and turn it that way. In most cases it gets put in the locked position and stays that way.
