Merc 130 Now only clicks.
greenerob
http://forums.iboats.com/showthread.php?t=167035
I read through this thread. I was hoping that someone could give me a little more guidance with me issue. Here is the skinny.
I tried to start the boat a week ago. It clicked once and didn't start. This happened a few times before it finally started.
On wednesday I got it into the water and the same thing happened. I tapped it with a hammer and it still clicked. Finally i got it to start. I ran it for awhile and when I came in to the dock I turned it off. After a returned with the trailer the start VERY weakly tried to turn and then quit. Now it does nothing but click.
Any suggestions?
Bt Doctur
Re: Merc 130 Now only clicks.
What are you tapping with the hammer?
starter?
If you have good clean tight connections, good battery, good cables, both positve and negative and power to the starter solenoids yellow/red wire, remove the starter and have it checked out at your local starter/alternator shop.
Bt Doctur
If the clicking is coming from the solenoid mounted on the starter, then it might need rebuilding at a local starter repair place. Check all battery cable connections first especially where the neg cable is connected
greenerob
Well, the click comes from the soleniod mounted on the starter. I bypassed the slave solenoid and it still just clicked. Looks like I need a new starter. Hopefully this one isn't a bear to got off.
greenerob
Is was the starter. Luckily I was able to pull it and replace it myself.
