merc 165 outdrive to a 470 mercruiser motor
lselmes
Just wanted to know if the merc 165 outdrive is compatible to the 470 engine? Any help would be much appreciated.
Bt Doctur
Re: merc 165 outdrive to a 470 mercruiser motor
All depends on the gearing. merc 165 should be 1.65-1 , 470 should be 1.84-1
lselmes
So what would happen if you were to run the 470 with the 165 outdrive, would it still run or would it be catastophic? Just looking for a hypothetical to what could happen with a mismatched drive/motor.
Bt Doctur
may need a lower pitch prop to get the WOT within range
