Merc 1976 500 stuck in forward previous owner replaced water pump did he incorrectl1
Davidmoody
How do I get the shifter working properly?
The cables are moving the shifter underneath the carbs..
What's wrong??
Texasmark
Re: Merc 1976 500 stuck in forward previous owner replaced water pump did he incorrec
First question, is: After his repair, did it ever work properly?
If no, then he probably didn't get the shifter spline lined up properly...he didn't have the shifter in the lower unit in the same gear as he had the shifter control and in doing so, when he engaged the splined shafts (lower unit to mid section) one wouldn't let the other go all the way too one end or the other and you lost the ability to shift to either F or R.
Or the spline shafts weren't even connected so even though the mid section female spline moved as desired with your comment in your post, the male spline in the lower unit remained where it was when he reassembled them.
So, yes, he could have reassembled it incorrectly.
If yes, you may have a broken/frozen shifter shuttle gear in the lower unit.
Mark
merc850
Take the LU off and do this: Turn the LU shift shaft by hand counter-clockwise until it
stops, then with Vise Grips tight on the bottom of the shaft turn it a
few more degrees CCW until it clicks into a stop, this
should be neutral - check by turning propshaft --
do not shift into reverse unless you turn the propshaft at the same time.
If it is in N go ahead and attach LU to driveshaft housing with control in N.
Lubricate the shift and driveshaft splines with a good grease (I use Mercury's anti-corrosion grease) because someday you'll need to replace the impeller.
