Merc 3000 control questions
imp0ster
So the 3000 box seems very flimsy and poorly made like it will break into crappy little plastic pieces. Is this normal? My father has a 4000 series shifter side only(the hidden piece isn't there) Will the visible side of the 4000 snug onto the 3000 control box hidden behind my gunnel panel?
Got pic's, there are several models of the 3 and 4000 series
OK I understand a bit better, and I believe there is a very good chance it would work. The issue with the one on ebay it appears to be one for an inboard not an I/O, don't see trailer function. Your 4000 is the same one on my Rinker and has been working fine. There are 4 different versions of the control cable box which the shifter bolts to but the spline from what I have found look to be the same.
imp0ster
Thanks! It's worth a shot. Wasting time is better than wasting money
imp0ster
Oh yes, even more so when there is beer involved
Completely agree. I have to wait for my bloodwork to come back before I drink anymore. Might have an adrenal gland issue or diabetes. 31 and I'm falling apart.
imp0ster
Won't work it's going to need the control box also according to GLS and a friend that already tried it. Oh well another project for another time
Is it from the spline being a different size or holes in the wrong place.
When searching, have not found a control which mentioned different model years, most say will work, maybe they have adapters, don't know
imp0ster
They didn't say I just got a bland answer. Looking at them I'm betting it's the mounting holes.
" Hello, sorry, it will not. You will need to go with a new Mercury 4000 series control. You will also need to change out the cables to the newer gen 2 cables.
Regards,
Great Lakes Skipper"
