Merc 350 Starter Removal
byrdman4u
HELLO ALL CAN ANY ONE HELP ME I HAVE THE SAME OUTBOARD MOTOR model 350 Mercury 35 Hp Outboard Motor HOW CAN I TAKE STATER OFF AND OUT THERES A BRACKET DOS THE FLY WHEEL HAVE TO COME OFF PLEASE HELP HERES SOME A PIC THANKS ALL JIM FROM MICHIGAN
GA_Boater
byrdman4u This is your new thread after moving the post out of an old thread. Take a look at the Help Tip on top of the page.
Take off the three wires on the solenoid with the arrows, the one on the large stud and the two on the small studs. Then remove the two circled bolts through the block. Move all the wires out of the way and tilt the top of the starter out of the block ears and lift it out.
GA_Boater
Let us know if you still have trouble removing the starter.
BTW - All caps is considered yelling.
jbcurt00
OK WILL DO THANKS
Ask questions here. Not in the 12yr old topic you posted to originally, which I closed.
Re-ask that question here.
AND turn off the caps lock. Otherwise it looks like you're shouting.
byrdman4u
still cant get starter back in on a 1967 mercury outboard 350 35 hp theres no room to slide it back in the bracket what do I have to take
GA_Boater
Reverse how you took it out. If you followed post #2, start reading it backwards from the end.
