Merc 5.7L Keeps Dying
sjohnson44
Fresh rebuilt Merc 5.7L Thunderbolt V wont stay running longer than 5 seconds or so. Tried feeding it gas through carb and still dies.
New mechanical fuel pump, no gas in sight tube
New fuel filter
Siphon valve cleaned
Fresh Gas
New coil
Carburetor rebuilt (Mercarb) Venturies were real dirty and had a lot gunk under the venturi cluster. Bowl had a lot of junk too. Stem works up and down smoothly, new power valve, needle and seat (spring type), cleaned metering jets, new acc. pump, new check ball and spring for the acc. pump "check valve". Used carb cleaner and compressed air. All passages clear.
Reused old float and set level to 11/32" and float drop to 15/16". New float they sent did not have the measuring dots on it so I didnt even attempt to mess with it. New idle mix screw, screwed all the way in and backed out 1 1/2 turns.
New distributor cap
New alternator
New battery, 12V everywhere its supposed to be.
Choke operates normally
Timing set to 10 degrees BTC.
Im at a loss and dont know where to start now. Since carb rebuild it does idle better but still shuts off. No matter if throttle closed or open.
Fishermark
Re: Merc 5.7L Keeps Dying
Doesn't the Thunderbolt V operate through an oil pressure switch? (I'm not sure if it does or not to be honest). If it does, try bypassing it and see if it stays running.
sjohnson44
I believe that is only used for the audio warning system and is seperate from the ignition circuit. I havnt seen anything that runs back to the motor from the audio warning circuit. When the switch detects 10psi or more it opens shutting the buzzer off unless there is another problem. The buzzer operates on my boat and shuts off once started. Engine has 30psi oil pressure.
Ayuh,.... Ya need to Identify just what yer motor is dressed as,...
It's NOT a 1996 vintage Mercruiser....
If it were, it wouldn't have a Mechanical fuel pump...
It sounds like a cob job built with This, 'n That....
When it dies,... LOOK, 'n See if it's lackin' Fuel, or Fire....
sjohnson44
Serial number 0F770506, mercurypartsexpress.com shows a mechanical fuel pump for that engine. Other sites identify that number for a 1996 5.7L.
Im going to recheck fuel pickup in the meantime.
Ayuh,... I donno how that's possible,... The SBC had lost it's mechanical fuel pump boss drillings by then...
Fishermark
Serial numbers are a great source... but sometimes you just have to look and see what you have. ;) Easy enough to see if you have a mechanical pump or an electrical pump. It sounds like an electrical pump that is not getting power once the engine starts.
Ayuh,.... I'm confused....
attachment.php
Do you have spark immediately after it dies? How long after it dies can you start it again.
Hook a jumper wire from the positive battery terminal to the + terminal of the coil and see if that keeps it running.
sjohnson44
The yellow tube that runs from the fuel pump to the carburetor. I have a mechanical fuel pump. I installed it.
sjohnson44
Sometimes takes a little while to crank again. Will try the jumper.
Cut those push on/spade terminals off those coil wires and put on some ring terminals and use the nut to hold them on securely. :facepalm:
And disconnect the gray wire from the tachometer if it dies with the jumper wire.
sjohnson44
There are no studs. I wish it did as that would be best practice.
Gee. I wonder if you would still have this problem with the correct coil installed? Just thinking out loud.
sjohnson44
Because it doesnt have studs or because its not rated to fire 8 spark plugs? Is there really that much difference between the one I got at NAPA and the one mercury says I should have? Does the NAPA coil only output 10kV and my motor needs 30kV to run correctly?
I dont mind buying a mercury coil, if its actually something worth trying. To me its all apples to apples, but Im probably wrong.
rpaldrich
FWIW--
Were the NAPA coils marine coils? And were they designed for Thunderbolt ignition? I just put new coils in my Thunderbolt IV, and on the side of the coils I purchased they said something about using an external resistor (or not using it I don't recall)....
But it seems that regular auto coils and non thunderbolt coils are different from Thunderbolt WRT this resistor, That could be your problem. I read a post from a while back talking about having issues w/ non thunderbolt coils.
http://forums.iboats.com/showthread.php?t=484204&highlight=quadrajet
EDIT: Post #8 specifically.
IDK if the coil is your problem, but Occam's Razor says the simplest solution is usually the correct one. Eliminate it as a source of problems and then you can narrow it down better. A new coil is only $35.00
Let us know.
John_S
Bondo, I think merc had allot of blocks in storage when GM stoped making the mech fuel pump boss. I have a K serial # 5.7L that has mechanical pump. According to merc, it was made Sept '96.
sjohnson44
FWIW--
Let us know.
New coil was $72, will be here next week. We will know soon enough. Thermal breakdown would make sense with this issue, as the engine runs the improper coil builds up heat and cuts out, once cool it works again.
Appreciate the link rpald.
