Merc 502 slow crank or normal?
thunder550
scoflaw
Ensign
Mine sounds like that,, 2 new batteries also. I've had mine for a few months and thought it was a bit slow as well.
Mine use to sound close to that until I replaced the starter with a permanent magnet type, now she spins fast
thunder550
Thanks guys. AllDodge, which brand did you put in yours? I see iBoats has Sierra, Arco, and ProTorque brands available.
Was it a direct replacement or did you have to make any wiring changes?
Mine is API, but would suggest the one I have, Wilson, Delco, Arco, but would not suggest Sierra
thunder550
Thanks. I read some bad reviews on the Sierra starter on Amazon as well. Will steer clear.
thunder550
I went ahead and ordered an Arco PMGR starter. Might not be necessary but the slow cranking always makes me nervous, I don't like the way it sounds even if it's fine. Might be in my head but I think it's a little worse when the engine is hot too. Hopefully this will alleviate any possible problems with the starter and my nerves.
San_Diego_SeaRay
Same experience. I swapped out my starter on my 7.4 and the engine cranked over much faster than before. I previously thought it was a bad battery but it turns out it was entirely the starter. (Only difference was that my original starter was a permanent magnet and so was the replacement)
San_Diego_SeaRay
My slow cranking resulted in a failed starter. So you're wise to nip it in the bud.
