Merc Drive identification 1991 Alpha 1
96lt4c4
I have a 1991 Glastron with a 5.0 Merc Alpha 1. The water pump is bad in the lower unit and I want to make sure I get the right one. I noticed when looking for pump kits that I might be right at a year/model change.
I am also thinking about going ahead and changing out the gimbal bearing and bellows since I think they are original.
JustJason
Re: Merc Drive identification 1991 Alpha 1
all merc ident's are done by serial number. it's on the valve cover, flame arrestor, the left rear of the block (when facing it) or in all 3 locations...
Do you have a serial number off the drive?
Being a 91, it could be a 90 Alpha I or a 91 Alpha I Gen II.
You need an outdrive SN, not and engine SN.
96lt4c4
I briefly looked for the serial number last night but didn't know where to look. Now I know where it is.
Thanks
96lt4c4
Whats the best shop manual that you guys would recommend for this drive?
Ayuh,....... The 1 from Mercruiser.........
Like Bondo states, the Mercruiser manual is the only way to go. I will give you a link to the online version, once we find out what you have.
96lt4c4
Roger that
That is a 1989 Alpha I drive, 1.65:1 gear ratio.
You need Service manual #6
Click here then scroll down to the outline and click on the section letter you want to view.
Yes, the pump kit you linked is the proper one.
