merc elpto 125 hesitation
fishnutt
I have a hesitation on takeoff. I took it to the dealer for carb adj he said it ran fine in the test tank. sometimes it idles rough and other times it pretty smooth. its a 2004 125 merc elpto w/ 4 blade prop. any help would be appreciated.
Texasmark
Re: merc elpto 125 hesitation
I'd do a decarb (archives) and then retest.
I had a similar problem. Depending on the load on the engine and temperature, I could get hesitation on an '02 90 hp 3 cyl on punching out of the hole (point of maximum load on the engine). After the decarb had thoroughly been absorbed, so that I knew it had done all that it could, I opened the low speed jets (only one adjustable) 1/4 turn,same on each carb and the extra fuel stopped the problem. May take a little more or less to get it right. Just enough to get the desired result, I'd think.
Mark
WillyBWright
Carb idle jet adjustments are going to be in the neighborhood of 1-1/4 turns out, +/- 1/8.
There's an accelerator pump to aid in acceleration. It shoots a little extra gas in the lower two cylinders which don't fire at low RPMs. If the throttle is babied, it doesn't pump. It needs a fairly decisive hammer-down to work.
fishnutt
THANKS GUYS. I could not locate how to decarb i am fairely new on here. could u please explain. thanks.
