Merc Prop Selector
youngboater
I was looking at Mercurys website and ran across the prop selector and it said I should have a 23 inch pitch prop for overall good performance? I am currently using a 19incher which came with the boat. I am running fine as far as RPMs go but maybe I could improve on the overall boat performance? It is a 2002 75 Merc 2-stroke 16.5 foot Aluminum Fishing if you want to look it up at their site. What do you think about this? Does a 19 inch prop sound about right? It says about 41 MPH estimated top speed. With GPS I am only getting about 32-34 MPH. The weight is evenly distributed and she weighs about 1500+people. THX
rickdb1boat
Re: Merc Prop Selector
What RPM's are you running now. That's the important thing to know for starters...
youngboater
4750-5250 is the recommended RPMs and I am about 4900 RPMs. I know that is fine as stated above. I was just wondering how credible the Merc. Prop selector is and if I should change props? All the recommended possible prop pitches are higher than my 19inch and I don't go near as fast as the say I could?
Your speed and performance sounds about right to me.<br />I don't know about their prop selector, couldn't get it to load. Perhaps they are figuring on a lighter weight for a boat that size.
rickdb1boat
Depends on the boat and the prop. No 2 are alike. The prop selectors are just a guide to get you close... Sounds like you are right on with the prop you have now and going to a higher pitch would result in poor low end performance and possibly lugging the motor, which can lead to a short life.. That 23" pitch prop would drop your RPM's about 800 and that would put you way out of the recommended RPM range.. I agree with roscoe that you are in the zone... You're talking about pushing a 2000+ Lb load by the time you are loaded up, with a 75 HP. Is that speed figure with a normal load or just you? If with the load, you are right on..
phatmanmike
my math says you should be able to go 44.7213mph with minimal gear and a perfectly flat day with no prop slippage......but......
walleyehed
In my experience, the Merc prop selector has always shown recommendations for higher pitch than that which puts you in the correct rpm range.<br />On my boat, a 25" is recommended, and I can't even come close to the low end of my rpm range with a 25". I've found this to be true of most all applications I've compared, on many different set-ups.
cobra 3.0
Just tried the Merc prop selector... it's totally full of cr_p! It recommends a 23 or 25 inch pitch prop for my boat for water sports...I use a 17" pitch and am in the correct rpm range.
youngboater
Roscoe I also typed in the weight and I still get the same results? <br />Rickdb1boat That is with a normal load. About 2 people and 27 Gal. of gas (full tank). The 1500 is about all loaded up except add two guys so figure just under 2000lbs. and getting these speeds. It is a Lund Deep V with full flooring and all the goodies including an 8HP kicker. I know it isn't a very light boat. It's max HP is 90 and max persons is 6 or 975lbs so I know it is not underpowered at all or overloaded.<br />Walleyehead and Cobra 3.0 I totally agree with both of ya.
