Mercruiser 120/140 fuel pump/auto crossover?
karhawk
I there a automotive pump that will crossover to the MC140?
Thanks
Chris
Oakland, Ca.
MexicoMike
Re: Mercruiser 120/140 fuel pump/auto crossover?
Greetings Kar, don't even think about it. Unless you want to risk blowing your boat and or yourself to smithereens. The marine fuel pumps are specially built to prevent a fuel leak into your bilge. Did you notice that your present fuel pump has a little hose running from it to your carb? That's in case if the diaphragm in the pump ruptures, fuel is dumped back to the carb instead of in your boat. Good Luck, Mike
Nope,... For the reasons stated by Mike....
zbnutcase
Nope...time to step up and pay for the correct pump. Automotive fuel and electrical parts do not belong anywhere NEAR a marine engine. 'nutcase
