Mercruiser 140 ign coil
simon666
Is there anything special about a merc 3.0l 140hp, with points ign coil or can i use a automotive one?<br />cheers
Re: Mercruiser 140 ign coil
I don't see a problem with it........<br />Just be sure to get the right one.........<br />Internal resisted, or external resisted.......<br />I'm not Sure, But I think you need External......
achris
More fish than mountain goat
Standard automotive coil will work fine. Just be sure to get one with "Requires external resistor" on it. These engines have a "resistive wire" in the loom. The coil is feed with about 7.5 volts while running.<br /><br />Chris...........
I have a mercruiser 120 hp. and just put a auto coil in with external resister. runs fine.
