Mercruiser 165 / chevy 250
CaptRon66
Last year picked up an engine in a hurry sold as a allegedly rebuilt Mercruiser 165. turned out to be a 235 ci engine. I swapped engines to get the season in. Propped down,dealt with some overheating issues and made it through the entire boating season April through December. Not happy with the loss of power in a already underpowered boat so I found a recently rebuilt Chevy 250 that came out of a Nova with good compression. The question is ..do i have to change the cam? I am aware of the wrong cams causing water ingestion but vaguely remember something about the 250 . That the cam in a stock 250 may not need to be changed.
Also... will be removing the head to replace the head gasket because I don't know if marine was used. Should this engine not be used if it was over bored more than spec in the service manual? Or should I place fresh water cooling system on the engine to prevent corrosion/cooling problems down the line.
Re: Mercruiser 165 / chevy 250
Nope,... No real worries with the Cam...
They didn't use any sort of radical cam in the car motors either...
I'd be more worried whether the block has the necessary Ear on the forward starboardside corner to mount the motor mount onto...
telstar1
A long time ago out of ignorance I ordered and purch. a 250 long block"car" model. Like Bondo says the ear on the corner is different. I made one up out of scrap steel in about an hour max and it worked fine so this is not a deal breaker. After I learned that I should have ordered a "marine"250 which has a truck?or marine cam and a steel timing gear, I swapped camshafts to the right one. I could NOT notice a performance difference although I suppose there may have been some differences I didnt happen to detect.Other difference is the brass frost plugs in a marine engine which only matter if you are raw water cooling which I wasnt.
CaptRon66
Yes, it has the ear . Made that mistake once in the past and made a bracket to make it work. I should have added the engine was rebuilt 3 years ago and ran in the Nova. Not sure what they did with the rebuild or which cam they used. It's unknown. engine was out of the car. I should have mentioned that. Still ok to run it ? Or should I at least take it out and ID it as stock? It's on a stand now.
zbnutcase
Wouldnt worry bout the cam either, not exactly peoples first choice in a performance engine...
