mercruiser 165 engine question
sd090107
the engine is leaking water pretty bad when running . when the engine is off just drips. down cylinder block. I found the manifold gasket online I was wondering if the mounting bolts are torque to yield so I know if I need new mounting kit. thanks for the advice.. sam
Re: mercruiser 165 engine question
Ayuh,.... The 165 4 cylinder, or 6 cylinder,..??
No torque to yield bolts are used anywhere on yer boat...
I'd sooner think you've got a cracked block,... Water doesn't pass through the intake manifold gasket...
sd090107
inline 6 . you think it can be a head gasket . the motor runs fine if water was getting in there it wouldn't really run. its coming from on between the exhaust and block somewhere high near the cylinder head where you can't just see in front of you.. I was under the motor with a flash light and you still couldn't tell where it was exactly
Fishermark
I'm with Bond-o on this one. It doesn't sound like a gasket problem. I would suggest pulling the manifold off and then you will be able to have a better look at the head - and manifold - to see if either one or both are the problem.
achris
More fish than mountain goat
Very common for those blocks to crack down below the centre core plug on the post side of the engine. You need to pull the manifold and then use overlapping cast iron 'rivets' to 'stitch' the crack... I would suspect the block has had an overheat. The other place they go is the port side front head bolt hole down to the top water pump mounting bolt.....
Chris.....
kilowatts
Hi Guys:
I agree with the previous posts, every cracked inline 6 block I've seen has cracked laterally just below the manifold. In order to inspect you have to pull the manifold. The symptoms describe a crack not a gasket leak! Either weld/stitch/repair the block or get a new block. I guess you know cast iron is very hard to repair,eh? Good Luck;
kilowatts
sd090107
you boys were right. there she is . worst is I just finished replacing deck and stringers . she was riding nice and solid on sunday so depressing . whT you think I should sell for with cracked block or if I replace motor there is a guy near me that has used motors dont know how much they are but its on a 2005 loadrite trailer rollers.. its a 1970 gradywhite chesapeake 212. thanks for all of your advice and help..
sam
achris
That looks like freeze damage... If you like the hull, I'd be looking for either a replacement block, or a complete engine.... Or even a donor boat with a half reasonable engine worth rebuilding. Try to sell it like that and you might get scrap value...
JMHO
Chris.......
ShowMeGuy
Dang man... Gotta be super diligent in winterizing these raw water cooled motors.
That looks all to familiar to my MErc 165. Mine ran but was getting water in the oil hence there was an internal crack as well. Maybe you could use a JB weld approach that is if it's not getting water in the oil??? I'm on the look out for a donor boat......
sam
Ayuh,... Are ya gettin' water in the oil,..??
If not,... Epoxy it up, 'n go boatin'...
If so,.. Find another motor...
sd090107
Bond -o what kind of epoxy would you recommend.. checked the oil its clean... and would my approach be to drebel a v notch where cracked drill pilot hole on either side of crack so it doesn't continue to crack then fill with the epoxy..
sam
sam
Ayuh,.... That's 'bout right,.... use whatever epoxy ya want....
sapita 1
:eek:On my 165, some rods were installed before i got it,I found the nut that holds the rockers down loose,at what torque should they be tightened,
Welcome aboard sapita, you need to start your own thread with your problem, and your information. Then you won't be overlooked by posting at the end of someone elses old thread.
