Mercruiser 190: What is the automotive equivelant for coil, wires, filters ?
I realize that this one is built by Merc. but there must be some cross referance for spark plug wires and the such. Any help?
Re: Mercruiser 190: What is the automotive equivelant for coil, wires, filters ?
Easy way is to hit your local NAPA and ask for parts and specify that they are for a marine application. Most filters are the same for both. NAPA can distinguish what is available.<br /><br />Bob :)
aerwin
is this a v-6 or v-8, ford has distributer in the front, GM has in the back, v-6, gm is probably the 4.6 liter, v-8 gm it's the 305 ci, v-8 ford its the 302 ci, I don't know what v-6 fords were used in marine. just make sure they are narine grade, wires, starters, alternators, etc<br /><br />Andy
aerwin
mercury did use an in-line six cylinder also before the 4.6 liter, I don't know the displacement, ford in-line six was the 300 ci
DP
I am guessing that you are talking about the 4 cylinder Mercruiser 190. The block is 1/2 of a Ford 460 but the engine was designed and built be Mercury.<br /><br />Follwing are some part numbers that may hep you, these are Sierra numbers that can be found or crossed at a NAPA store. These are for the 4 cyl.<br /><br />Dist cap 18-5385<br />Rotor 18-5418<br />Condenser 18-5345<br />Points 18-5311<br />Plug wires 18-8808<br />Oil filter 18-7824<br /><br />NAPA used to have a marine catalog, their marine engine parts are made by Sierra.
