mercruiser 200hp no forward or reverse
DaveyHAZZ
Have a 200hp mercruiser engine matched with a alpha one drive.Today i go to start her up, she starts fine. Go to put her in gear conks out either way. Any suggestion on to what this problem could be? thanks in advance
Bt Doctur
Re: mercruiser 200hp no forward or reverse
conks out, like shuts off ? may be the shift interupt switch because the cable is frozen/damaged/siezed.
DaveyHAZZ
yes it shuts off completely..last year it was only reverse now its both. where is this switch located?
DaveyHAZZ
the prop wasnt on if that has anything to do with it. this is a winter startup
