mercruiser 260 doesnt stop turning over when key is off
ringmaster
my cousin just bought a motor with 50hrs on it. its a mercruiser 260 thunderbolt 4 with a alpha 1 outdrive. we was working on it today to do all the tune up stuff when we went to start it the motor kept rolling over when the key was turned off. the only way to stop it was to unhook the battery cables. now mind the motor isnt in the boat yet its on the floor in the garage. what would cause this? do i have a wire backwards? i have spark so i know that is good.
Re: mercruiser 260 doesnt stop turning over when key is off
Ayuh,...
The starter solenoid is Junk,...It's Stickin'...
Stuck slave or starter solenoid??????
ringmaster
thanks that is what i was thinking. but just wanted to see what other people thought. thanks agian
JustJason
double check that you don't have a sticking keyswitch as well.
