- Joined
- Mar 5, 2006
- Messages
- 30,797
Re: Mercruiser 260 low vacuum
Like I said before, you have a 4 stroke engine. #1 will alway be across from 6 and that cam can be assembled 180 from what you show in your diagragm as long as the engine itself is at TDC.Well, I'm eliminating a mechanical timing problem as the source of my low vacuum. Found something on the 'net that explained my timing gear mark confusion. When the cam gear and crank gear marks are both at 12 o' clock, the #1 cylinder IS at TDC of it's compression stroke. When you're assembling the engine, and you line up the marks at cam 6, crank 12, the engine is actually at #6 TDC compression. So, I'm back to square one. Time to pull the intake, and reassemble it with new gaskets. If that don't clear it up, guess it's going to the shop.View attachment 109279
