Mercruiser 3.0 L oil pressure switch Question
dmoccia
Took out my oil pressure switch to check it. Problem is my manual no 26 shows a test procedure for a oil pressure switch with only one terminal connection whereas my switch has a three pronged connection. Haven’t been able to find one online that matches mine. Any ideas?
1960 Starflite
Think you have the TKS carb oil pressure switch and is part of manual 41
Block diagram of how its used
