Mercruiser 3.0L shifting out of gear to neutral engine stall
jaa241
Hey guys, I have been working on a boat recently. Replaced the shift cable, all those bellows and such. Did the shift cable adjustment as per Achris's video which was great. Took the boat in the water, shifts great into both forward and reverse, but stalls most of the time going back to neutral. The shift cable with drive installed is very smooth.
Sometimes it stall the engine, but some other times it actually goes into neutral at the control box but does not come out of gear. The throttle arm needs to be shaken back and forth and eventually the shift interrupt switch does its job, stalls engine for a msec and then comes out of gear. Other times is stalls completely.
I checked the timing with a gun and it is right on along with the dwell.
Lower shift cable is new
Could it be an issue stated in achriss video comments of the grub-screw being to tight?
This is a mercruiser 3.0l Chris craft scorpion 168. I'd appreciate any help
Re: Mercruiser 3.0L shifting out of gear to neutral engine stall
Did you use an oem cable or one of those cheep aftermarket ones? Was the shift slide adjusted properly? Too tight and it will stall the engine.
What drive do you have? Serial number, maybe even year will work.
jaa241
Purchased it in a kit, with bellow,seals and such. How can you determine if it was an oem or cheap aftermarket
It's alpha 1 gen 1. I will get you the serial number tomorrow.
Thank you very much
What was the part number of the kit?
jaa241
Shift Cable Bellow Transom Repair Kit Adhesive for Mercruiser Alpha One 1 | eBay
Don't believe it had a part number or anything on the bag it came in.
Do you have a part number of a the oem shift cable I should order and would it be possible to replace the cable without taking off the gimble housing? or would it be okay to just slide out the core and replace it the oem one? Thanks again for all your help
jaa241
Would you know what part number would be for a lower shift cable for the alpha one gen one?
jaa241
quicksilver 865436A03
So do you think it would be possible to replace the cable without separating the bellows. Thanka again
the quicksilver kit comes complete with bellows
it would be virtually impossible to remove the cable without removing the bellows forn the transom assy
achris
More fish than mountain goat
Yes.... BUT, that kit is a VERY cheap (and most probably) nasty enough to be your problem. I would also toss ALL that other parts... We have a member here, Fun Times. His signature is something to the effect 'OEM parts will be cheaper in the long term'. It's very true. You have a nasty cheap rubbish uni-joint bellows on... How much is the cost of repairing all the parts that will be damaged when it leaks? Considerably more than the amount you 'saved' by using the cheap parts in the first place!
Chris............
achris
it would be virtually impossible to remove the cable without removing the bellows fron the transom assy
Bit of engine oil and it slides through nicely. (once the top end is dis-assembled).... :D
Chris.....
jaa241
Thanks guys!
Also I have been looking up transom seal kits and just bellows do you have any suggestion on those such as a part numbers.
So atleast replacing the shift cable should get rid of the going into neutral and still staying in gear issue, correct?
achris
Use OEM parts and you'll have less problems.
OEM Transom seal kit (all bellows, gimbal bearing, gasket and a few other bits and pieces) 30-803097T1
OEM shift cable -865436A02 (if you are NOT getting the transom seal kit, use cable number -865436A03. It includes the bellows and gaskets etc...)
These are for drives before 1991. You still haven't supplied your serial number, so there is a chance these could be wrong...
Chris.......
jaa241
Thank you very much.
I have already read it could be an issue with the castle nut found by the clutch. Could that be true if it worn down. I will go e you serial after I get out of work. Thanks again guys
achris
You're going to have to define this a little differently. What castle nut? and the only clutch in the drive is the dog clutch in the gear housing, and there is no castle nut anywhere near it (in fact, there are no castle nuts in the drive at all... are you referring to the drive-shaft housing cover nut??? maybe????....)
Chris........
I do believe he is referring to the castle nut on the end of the shift spool.
Not sure why, it will not cause his problem. Just wanting to find something wrong that isn't. The cable and/or the the adjustment of the cables is the problem, or maybe the shift shaft bushings being corroded and binding. But not the castle nut on the shift spool :facepalm:
achris
I do believe he is referring to the castle nut on the end of the shift spool....
Oh yeah... Forgot about that one... Been a while since I've needed to go there.....
jaa241
Gimbal housing serial is 0823284
And outdrive serial is 6873784
Is it possible to tell what year these were manuf, in
Thanks
achris
Thanks
1985, and I think you'll find that the gimbal housing serial number starts with a 6, not a 0.
jaa241
Thanks. It probably is. It is very washed out and hard to read. Thanks. Waiting on replacement of new cable. Hopfeully in this weekend.
