Mercruiser 3.7/470 Overheat Problem
Alterry
I have an old 470 which I’ve had since new, 39 years ago. It is overheating after running at cruising rpm, say 3500 or so after a few minutes. I’ve replaced the thermostat, sea water pump, and cleaned the heat exchanger. There is water flowing through the exhaust ports and exhaust at the bottom of the bell housing.
The engine will idle at normal temperature all day long, as soon as you take for a run though fluid begins to flow into the coolant recovery tank and the temperature rises
There is no coolant in the oil or oil in the the coolant, and the compression on all cylinders is around 139, there is not much change between cylinders or if the check is made with the engine warm or cold.
However when you perform the running check at cruise that mercruiser recommends, which is to run the boat at 3500 rpm with a clear line attached to the coolant recovery tank and reservoir, fluid does move rapidly through the line. Mercruiser states this is indicative of a head gasket leak at combustion compression pressures that doesn’t show up during a cranking compression test.
I’m wondering if anyone has any further insight on this.
kenny nunez
You have a head gasket leak. What you are describing is a common problem. Have a valve job done and get the head resurfaced.
You will never see where the gasket is leaking. The cylinders have no lateral support and over time they tend to “walk” from side to side.
I guaranty changing the head gasket will be the fix.
When the head is off be very careful not to scratch the aluminum block surface. 400 grit sand paper on a flat file with mineral spirits will clean the surface.
kenny nunez
There is 1 other thing you need to check. With the engine running on a flushout or in the water remove the hose from the drive pump and try to stop the flow with your hand. You should not be able to, If you can stop it then the plastic water pocket cover in the upper section of the drive shaft housing is leaking because it is melted. Or the hose between the bell housing and transom plate is the problem.
Alterry
Thanks Kenny, I’ll try the hose check and see if that works
Alterry
When I remove the hose from the heat exchanger inlet and put my thumb over it I get a little water squirting past my thumb, very similar to what you would have if you put your thumb over a garden hose. This is running at idle rpm
Alterry
A little more info, I just tried it at 2000 rpm, I’m able to almost completely stop the flow with my thumb. It does pump water through, almost a gallon in about thirty seconds
Alterry
You still should pull the head.
There are 2 types of 470 head gaskets, the ones that are leaking and the ones that haven’t started leaking yet.
Thanks Kenny, that’s the direction I’m leaning. There’s a local machine shop that will rework the head for $350. The mechanic is familiar with the 470 and they do a lot of engine work so I’m pretty confident they’ll do a good job.
The water hose in the bell housing probably has ten years or more on so it is suspect, but I didn’t see it leaking when I checked. I’ll pull the bell housing while the head is out for repair, might as well get after everything there. Now all I need is time to do it.
kenny nunez
The head comes off pretty easy, however there are some bolts under the intake manifold going into the head which cannot be seen from the top.
Also be sure to tell the machine shop to replace the air injection plugs in the front and rear of the head.
kd4pbs
The 470/488 is like sushi. When it is good, it is amazing. When it is bad, it might kill you. Fastest boat I have ever owned has a 470. Amazing power from such a light engine. No wonder they are sought after so much by hot rod builders.
The Ford head is dead simple to work on. I have to wonder if an aluminum aftermarket head would be a worthy investment for someone who has to replace one anyway. I imagine someone has done it and shared the experience.
ROY WILLIAMS
1978 MCM470 ENGINE [WILLIAMS]. heater exchanger 50% water distilled - coolant antifreeze 50%.
engine oil 30wt 5.5qt. ENGINE LUCAS TB ZINC - PLUS ZDDP 4 OZ. outdrive water sea water / water pump. gasoline filter water. gasoline 90 OCTANE. ENGINE 650 RPM IGNITION 4 DEG BTDC.
470 MCM 4cyl piston compression pressure 140lbs.
Do you have the 3 or 4" heat exchanger? Here is a TSB from the "sticky" at the beginning of this forum on checking water flow from the drive to confirm there is enough before moving on to another possibility:
Link to TSB
stonyloam
So, after 15 years or so my 470 head gasket blew for the second time. Not a bad run and not the worst job in the world to replace, except it seems that the OEM hg is no longer available so I got one from Sierra. Looked at it and it was cra….. uh not up to Mercruiser standards, so looked around for a better option. Wound up going with a Cometic 460 Ford (Ford 385 Series .040" MLS Cylinder Head Gasket, 4.600" Bore) little expensive ($107), but it was a work of art and a PERFECT fit. Iinstalled it and she’s running like it’s 1990 again.
stonyloam
Just finished that job. Went with a Cometic 460 Ford (Ford 385 Series .040" MLS Cylinder Head Gasket, 4.600" Bore) perfect fit. Talk to your machine shop about a 460 Ford high performance head gasket rather than one of the marine aftermarket ones.
nola mike
hey Terry! where you been?
nola mike
LOL, been lazy, boat has been in the garage waiting for me to get my butt in gear to get it running again, she is purring like a kitten. Not many 470s around any more for folks to work on, but I still enjoy mine, even with all its quirks.
been 5 years since I swapped mine for the 4.3. still have 2 3.7 bobtails in the garage...
