Mercruiser 350 Vacuum Advance??
LiquidC
Got my new motor & Edelbrock carb all setup & working. There is a vacuum advance port on the carb, and I believe it's for an automotive distributor.
What should I do with this port? Cap it? I circled it in the picture.
Lyle29464
Re: Mercruiser 350 Vacuum Advance??
Does your fuel pump have a small hose coming off of it? That might be where it goes.
LiquidC
No, I have a Carter electric fuel pump. It just has inlet/outlet for fuel.
Ayuh,.... Which Edlebrock is it,..?? What model number,..??
LiquidC
Bond-o, it's the 1409 marine carb
Your picture is a bit small, but here is a 1409 carb, the arrow shows the fitting that the overflow clear hose from a mechanical fuel pump would attach to. With an electric pump, that is normally just capped of with a rubber cap.
LiquidC
Thanks Don
Now to find a tiny rubber cap .....
