Mercruiser 4.3 with thunderbolt IV ! Keeps bogging !
I thought this May help some people , I recently was working on a 1994 Mercruiser 4.3 thunderbolt IV motor , first time in water the motor would bogg it you tried to give it full throttle it would only do 35 top speed seem if it was staving for fuel. So I pulled the 4 bbl carb and cleaned and rebuilt it took out to water again same problems and then was popping thru intake so I said had to be a coil , so I had an extra coil I thru on it and put new plugs and wires in it and it seemed worst , so I replaced the rubber feul line and the check valve in the tank , and it was worst the next time out so I lifted the motor cover and watched everything and caught the coil arcing out the side , so I put another this time brand new out the box coil I go back to lake and water was really rough and it was still bogging and then motor shut down wouldn't start back up and I knew had to be dam exhaust flappers and I was right they had fell apart so new flappers and I starting checking all my connections I took off all grounds and I put a heavy gauge ground wire and cleaned the studs on motor , then couldn't get to start the starter bendix wouldn't kick out fully would just spin real fast so back to checking all wiring again to starter and alternator and in harness . Then I went to front of boat to ignition and looked under dash and noticed someone had unplugged the buzzer under dash from ignition and I seen the ignition I guess they didn't tighten the wires back down and the screws holding them tight were about to fall off so every time I would go out I was losing connection at the ignition switch and it just got worst and worst I tighten the ignition wires and everything was fixed no moroe bogging boat will do 55mph on water now and starts right up ! Thought this may help someone hopefully because I went crazy chasing the problem down !
Ayuh,.... That gives yer Handle alot more meanin',....... ;)
Heywire77
The heywire77 was because it is same as my old email and easy to remember. But yes a boat can drive you hey wire ! First thing I do when I get a boat I'm working on is to go thru all the wiring and clean it all up because of them being in water I find a lot of corroded wires !
achris
More fish than mountain goat
It's because of that corrosion I recommend replacing any glass type fuses and holders with the water proof 'blade' style fuses and holders...
Heywire77
Yes never worked on anything with glass style fuses , most things I see is 1990 or newer .
Volphin
Bondo, you owe me a keyboard. Just spewed coffee all over mine reading this post. LOL
Heywire77
volphin just a keyboard what about you pants you pissed ?
Volphin
Oh my. oO
Did that make you feel better about the gauge of your wire? Blatherskites are compensatory by nature.
