Mercruiser 4.3L MPI PVC valve
wildemike
Does anyone know the part number? Can I go to the NAPA or Advance auto store and pickup one? TKS Mike
Re: Mercruiser 4.3L MPI PVC valve
Ayuh,... Do you mean PCV,..?? What's the matter with the 1 you have,..??
They rarely go Bad...
Btw,.... Read below....
V
V
V
wildemike
PCV Valve I thought you had to replace it periodically, mine has been in there since 2002. I have all the manuals and it's not mentioned anywhere.
JustJason
just shoot some brake cleaner + comressed air through it
180shabah
Only if they go bad periodically, but then you need to find the real problem.
mkast
Depending on the year, it may be hollow. All it's used for is to attach a hose.
