Mercruiser 470 Starter
hi all,
looking for your thoughts. our starter has gone bad and looking to get it rebuilt. The local rebuild shop has suggested that we do not have a marine starter and wants to sell us a new one. Apparently, the starter doesnt have the shield for sparks and this could obviously cause a fire because of fumes...
thoughts? we have never had it replaced but not sure what the previous owners have done.
I have to admit, I didn't know that myself. lol..
I've always had my original starter rebuilt. We have great local shop that does alternators and starters. You should see his shop, it's a disaster of parts scattered, but he knows what everything is. The last time I went there, I didn't even have to wait for mine to get done. He had a couple already rebuilt I just did a swap and paid him.
470 uses a standard chevy starter.
No
470 uses a ford starter. Factory came with a divorced solenoid. There are newer style ford starters that have the solenoid mounted on them but fitment can be an issue with these
nola mike
No
Yup, meant to follow up on this. I knew it was an auto pattern, makes sense that it's Ford. The newer 470s (3.7) do have an integrated solenoid with a slave, the earlier ones don't have the slave. Thanks for the correction.
ROY WILLIAMS
hi all,
THE 470 engine starter has a total shield .then the engine cranks and does not start the engine , then the starter has a brake to not rotate in the wrong rotation . when the engine starts the starter drops the brake rotation ..
bushings / motor commutator brushes ....fix it ..
Ayuh,..... Good thing I don't mind Baloney, now, 'n then,.... :rolleyes:
I thought they're flange mounted,....
ROY WILLIAMS
the previous owner changed the wrong starter motor ? ok ....
ROY WILLIAMS
Sorry I missed this. I am a bit confused. You believe I have the wrong starter?
so you fix the engine starter ? you can buy the starter
MHA7016 STARTER MOTOR ,,,,,MCM470 1978
www.obbstartersandalternators.com
5660 - Mercruiser Starter Motor - OBB Starters and Alternators
Mercruiser Engine Marine Starter Motor, Mercruiser Stern Drive Starter Motor Replacement for Prestolite Dd, 12v, 9t, Cw, Remanufactured, 5660, Mercury Marine 50-72550, 50-72550a1, Prestolite 46-2273, 46-3599, mha6104, mha6104s, mha7016
Application: Mercruiser Engine - Marine
Model 470 MIE Mercury 3.7L - 224ci - 4cyl 1980-1981
Model 470 Mercury 3.7L - 224ci - 4cyl 1976-1982
Model 485 Mercury 3.7L - 224ci - 4cyl 1980-1982
Yes we got ours repaired
