Mercruiser 470 trim motor help
droptine77
Hey guys need your help with this one.1979 mercruiser 470 with Prestolite trim pump. I know the motor needs rebuilt but I can't find no part number. There is HYC 5008 and 46 78 on the bottom but I haven't been able to Google anything or find anything on here. The tank has 8 screws on the bottom. Anybody got a clue as to where I can find the part number or model number to get replacement parts?
Re: Mercruiser 470 trim motor help
Ayuh,... I'd just Update it to the newer plastic tanked model...
greg82255
If you really wanted to you could just replace your motor and tank for $200:
http://www.amarket.com/ipt003.htm
But I agree with Bondo, I spent 2 years messing around cleaning the brushes on the prestolite pump and trying to rebuild the motor literally every few weeks. I got so fed up that I went for the newer style he suggested. I believe you can get a brand new one from SEI for $300:
http://www.sterndrive.cc/mm5/mercha...ode=9C-108&Category_Code=MercruiserTrimSystem
They're often found on ebay too. If you choose to get the new pump, the threads on your hoses will not work (yours are 3/8-24, you need 7/16-24). You will need some adapter fittings to get them to fit in the new pump, which is quicksilver part # 22-77366. Best of luck
droptine77
Thanks guys. The pumps I seen where a heck of a lot more than that. That's what I will do. Thanks again.
