Mercruiser 5.7 engine riser gasket
marife
Can someone explain why my engine (OF353346, '94) uses a riser gasket with two largge orifices and two small, while the exhaust manifold has 4 large ones?
Regards to all
Re: Mercruiser 5.7 engine riser gasket
Ayuh,... The differences in manifold gaskets is dependent on the T-Stat Housing used in that particular application....
Use the Wrong 1s, 'n an Overheat is in yer future....
backyard mechanic
Multi purpose gasket- Fits more than one riser application. Be sure to use the right one for FWC and raw water cooled applications.
