Mercruiser 5.7 Exhaust Tube
Red955i
Mercruiser 5.7 has a metal tube (covered with a rubber sheath) that runs from Starboard Exhaust to Intake manifold....This part is simply referred to as an exhaust tube in the intake manifold diagram. Question...What is the actual purpose of this tube? Does it carry exhaust gas to intake to recycle? or Does it carry water? When i moved the sheath I see what looks like steam come out so I am wondering it the metal tube has a leak and what the actual purpose is before I spend $150 to replace....Thanks Bob
thumpar
Edit: I read your post a little better. I am not sure what tube your are referring to.
Normally an exhaust tube is a tube that replaces the exhaust bellows. It is easier to install. It goes where the bellows would be but is not sealed on the drive side. The engine will be a little louder than with bellows.
Red955i
No Title
Please see #4 in diagram
Fun Times
Be careful as that tube between the exhaust manifold to the intake manifold is the hottest part of the engine as it gets over 210 degrees.
It's primary use is for better emissions and is just exhaust gases transfer. Shouldn't be any water in there. 32-807727A2 TUBE-EXHAUST,
th
juliolop
th
thanks I had the same doubt, can you tell me exactly how it is connected (what port) in the starboard exhaust manifold. if you have a picture or diagram definitely is going to be better.
rgds
Fun Times
rgds
Below are some images I found online for you,
Item # 5, 22-805563 CONNECTOR, (.500 Inch NPTF To .500 Inch Inverted Flare) (.50 Inch NPTF To .50 Inch Inv. Flare) http://www.mercruiserparts.com/bam/subassembly/31837/2697/180
th
​See the brass fitting next to/left of the carburetor base studs, The tube connects there on the intake,
